G4Captain
Jul 19, 2018Star
Setting up a static route.
So I'm trying to set up a static route for my surrond sound system, so it's easier for my wife to use the sound system. I put in all the information that it asks for, including the IP address that is...
- Jul 19, 2018No that's a different feature, under LAN Setup add a reservation for the device
dpower22
Aug 09, 2018Initiate
Hi I trying to set up a static route to block google dns. When i enter 8.8.8.8 or 8.8.4.4 and click apply the router changes it to 8.8.8.0 & 8.8.4.0. I am on the latest firmware
Netduma-Fraser
Aug 09, 2018NetDuma Partner
What do you mean by block Google DNS? If you don't want to use it then just change your DNS to something else
- dpower22Aug 09, 2018Initiate
https://support.overplay.net/hc/en-us/articles/360000173593-Blocking-Public-DNS-Netgear-Router
I figured it out, I changed the IP Subnet Mask from 255.255.255.0 to 255.255.255.252 and google dns is now blocked. Thanks for getting back to me.
