Hedake
Feb 15, 2018Aspirant
Setting up Access Point
Hi, TLDR - How do I setup a Nighthawk X6 to act as an access point for an XR500 (Main Router)? Overview I just installed a XR500 as the main router in our house. I would like to setup our ol...
Netduma-Fraser
Feb 15, 2018NetDuma Partner
Hi John, just to clarify you want to set up the X6 in access point mode to connect behind the XR500 and use that for WiFi? If so then you just need to connect the X6 to the XR500 and then follow the references you've found to put the X6 in access point mode. You won't need to do anything on DumaOS.
If you want to set the XR500 to access point mode then its in Settings > Setup > Router mode, though I would not recommend this because you would not be able to utilise any of the XR500's amazing features.
- HedakeFeb 15, 2018Aspirant
Hi Netduma-Fraser,
Thanks for responding. You are correct the X6 is the access point. I connect the X6 to the XR500 via cable as the reference says but when i got to the routerlogin page, i get the DumaOS and cannot find an option to set the X6 to access point. Do I need to disconnect the XR500 and just have the X6 online and goto routerlogin with that? Sorry if I am confusing it. I just cant get to where I see the X6 to set it to an access point.
Thanks,
John
- Netduma-FraserFeb 16, 2018NetDuma PartnerHi John,
The easiest way would be to change the XR500 or the X6's LAN IP before you connect it to the XR500. Then when you plug the X6 into the XR500 you go to the interface of the X6 via the LAN IP rather than using routerlogin.net.- schumakuFeb 16, 2018Guru - Experienced User
Netduma-Fraser wrote:
The easiest way would be to change the XR500 or the X6's LAN IP before you connect it to the XR500.Assuming the X6 is already in AP mode, check the XR500 Attached Devices/DHCP table for the IP assigned to the X6.
As the X6 does not handle DHCP and DNS, the routerlogin.com and Co. can't be used to resolve the X6 LAN IP address in AP (or bridge) mode.
