Bud1210
Jan 03, 2019Aspirant
Setting up Home Network
Good Morning,
I’m looking for some advice on setting up my home network.
Currently we have a BT Fibre and home hub but i’m looking to upgrade. Currently the BT line Is situated in the lof...
Netduma_Jack
Jan 04, 2019NetDuma Partner
Hi Lee,
There's probably no real reason to replace the hub with an alternative modem - from my experience BT Hubs are pretty well made and using a new modem can be a bit of a hassle with some British ISPs.
I think what you need are powerline adapters. These allow you to transport a wired Ethernet signal through your mains power supply (pretty cool gadget!)
So I would do this:
- Leave the loft -> BT Hub setup as is
- Connect the XR500 the Hub
- Connect nearby PS4 to XR500
- Use two PowerLine Adapters - connect via wire to XR500 and transport ethernet to other room
- Connect two consoles in other room into powerline adapters
Also, if you don;t yet have th XR500, I would recommend following these three guides to get it setup optimally for you gaming needs:
- Open NAT: http://support.netduma.com/support/solutions/articles/16000076587-dumaos-optimal-settings-guide-open-nat
- QoS: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
- Geo-Filter: http://support.netduma.com/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
I'm sure other people on here will have their own ideas too!
Netduma_Jack
Here's a link to some Powerline Adapters - you'll either need two pairs on one pair + a switch to allow for two connections in the other room:
https://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=powerline+adapters
- Bud1210Jan 04, 2019Aspirant
Thanks for the reply I appreciate it. Currently the BT home hub is in the living room, do you think I should move this up into the loft? The reason I was looking to go away from the BT home hub is the X Box will not connect to it, so if the XR500 is connected to the BT hub will this then work?
I was hoping to have 2 WiFi routers one in each room downstairs, it doesn’t look like this possible having the power line adapters?
Cheers Lee
- Netduma-FraserJan 04, 2019NetDuma PartnerI'm not sure why your Xbox won't get a connection to the BT Hub, likely some configuration issue there so putting the XR500 between them should resolve it. You could put the home hub in the loft if your setup allows it. Then have a powerline adapter connected to it that feeds into another room where you could have the XR500 available for wired and wireless connections. I don't see an issue with using two routers with powerline adapters but it may be unnecessary expense if the XR500 WiFi can reach both rooms.
- Bud1210Jan 07, 2019Aspirant
Okay thanks again, so would I be setting up the BT hub as a modem? Does the XR500 then become a access point, if so do you get the full functionality? I really wanted to ditch the BT hub as I have read so many bad reviews on them.
Is it necessary to use these Powerline adapters? As i’m not to keen on the idea of using these
sorry for the questions, i’m new to this and want to understand as much as I can.
Regards Lee.
