droesw
Oct 24, 2019Guide
Settings for lowest latency?
I have an xr500 and a docsis 3.1 modem my isp provided to me, and I play xbox one on ethernet. I know that it’s recommended to use QOS and the geo-filter to help with latency and overall gaming connec...
Oct 24, 2019Guru - Experienced User
What SPEED up and down do you pay for from your ISP?
What is the mfr and model # of the ISP modem your using?
I use 70/70 on my XR450. C7800 in modem only mode. 200/10 ISP service. Two game consoles online. sometimes at the same time.
Netduma-Fraser
Oct 24, 2019NetDuma Partner
Firstly make sure you follow our optimal settings guides: http://support.netduma.com/en/support/solutions/folders/16000090646 after that there isn't really any other settings that would significantly lower your ping. Make sure you're playing via an ethernet cable but if not use 2.4GHz WiFi - not 5GHz and use the least congested channel.
