droesw
Oct 24, 2019Guide
Settings for lowest latency?
I have an xr500 and a docsis 3.1 modem my isp provided to me, and I play xbox one on ethernet. I know that it’s recommended to use QOS and the geo-filter to help with latency and overall gaming connec...
droesw
Oct 25, 2019Guide
I pay for 200/10, but usually when I do speed tests without QoS enabled I get around 230/12.
I'm not finding any mfr number, but the model number is Ubee E31U2V1. And like I said it's a docsis 3.1 modem, and my isp is spectrum.
Netduma-Fraser
Oct 29, 2019NetDuma Partner
Did you follow the guide to optimally set up the router? How are you getting on?
- droeswOct 29, 2019GuideYeah I used the optimal settings guide for QoS but all the other settings I left default as I heard they shouldn’t usually be messed with. I also just changed the channels for my wifi bases off of the channels my neighbors were using, but otherwise I haven’t changed much. I haven’t touched the geofilter because the game I primarily play has one dedicated server on the east coast and one on west, but it always automatically connect to the East server, so I’m assuming using the geofilter wouldn’t really affect me then, right?
- Netduma-FraserOct 29, 2019NetDuma PartnerGlad to hear it, sounds like you'll be sorted. In that case where there are only two servers to choose and it is putting you on the right one then you don't need to use Filtering Mode. It could still be useful to use it in Spectating Mode however so you could ping the server when playing.
