Marv-K
Aug 05, 2021Guide
Settings XR500
Hallo , ich habe eine Frage. Ich habe mit meiner Fritzbox 7590 eine Internetgeschwindigkeit von 156 mbits download / 20 mbit upload. Ich habe mir den Nighthawk XR500 router geholt um hauptsächlich de...
- Aug 06, 2021
Looks like the issue is as Fraser suggested.
Please go to the three-line menu in Anti-Bufferbloat and select "Set Bandwidth Speeds". Enter here what you expect to get from the ISP and retest.
Netduma-Fraser
Aug 05, 2021NetDuma Partner
Also have you entered the speeds you expect in bandwidth settings? Check the table view for the Device Manager, are any of the ports limited to 100Mbits?
