babybypug
May 19, 2020Guide
Setup Port Fowarding help on Pc please?
I have all the ports ranges for battlefield 5, Modern Warfare Warzone etc.. But when i go to advace settings then click on porfowarding utilizing a static ip. Surfed youtube more xr500 than xr700 ca...
Netduma-Fraser
May 19, 2020NetDuma Partner
What platform are you playing the games on? UPnP should open the ports needed for the games, do you have an Open NAT already? The port settings will be the same for either router so no differences there.
babybypug
May 19, 2020Guide
Windows 10 64 bit . My Nat it's saying moderate in MW Warzone, and lag spikes in battlefield any help will be appreciated thanks.
- Netduma-FraserMay 19, 2020NetDuma PartnerAre you using the Geo-Filter as this can sometimes cause false readings of NAT. This guide should help you with Port Forwarding: https://kb.netgear.com/24290/How-do-I-add-a-custom-port-forwarding-service-on-my-Nighthawk-router
Lag spikes are probably not related though. Are you using QoS?- babybypugMay 19, 2020Guide
qos off and bloat off so far. thanks for the link gonna go try it.
- Netduma-FraserMay 20, 2020NetDuma PartnerI would definitely suggest using QoS as that will prevent you getting local congestion/lag.
