babybypug
May 19, 2020Guide
Setup Port Fowarding help on Pc please?
I have all the ports ranges for battlefield 5, Modern Warfare Warzone etc.. But when i go to advace settings then click on porfowarding utilizing a static ip. Surfed youtube more xr500 than xr700 ca...
babybypug
May 19, 2020Guide
Windows 10 64 bit . My Nat it's saying moderate in MW Warzone, and lag spikes in battlefield any help will be appreciated thanks.
Netduma-Fraser
May 19, 2020NetDuma Partner
Are you using the Geo-Filter as this can sometimes cause false readings of NAT. This guide should help you with Port Forwarding: https://kb.netgear.com/24290/How-do-I-add-a-custom-port-forwarding-service-on-my-Nighthawk-router
Lag spikes are probably not related though. Are you using QoS?
- babybypugMay 19, 2020Guide
qos off and bloat off so far. thanks for the link gonna go try it.
- Netduma-FraserMay 20, 2020NetDuma PartnerI would definitely suggest using QoS as that will prevent you getting local congestion/lag.
- babybypugMay 20, 2020Guide
Okay i setup up the custom port forwarding and went in to see if my nat changed and it was still saying moderate in warzone . Gonna activate qos and change my geo filter from 500km to may be 1000km that may help . I'm connected to a comcast modem wired i never set it to bridge mode just connected and lowered my geo filter and started playing. Learning alot from this community and youtube comes in handy. Thanks alot for your help
