BrashCandicoot
Jun 16, 2018Follower
ShoreTel/Mitel QoS on Nighthawk router
I am planning on getting a Nighthawk gaming router for my home soon. I also work from home and use ShoreTel/Mitel. It looks like the QoS feature picks up applications for you to set priorities. Does t...
Netduma_Jack
Jun 16, 2018NetDuma Partner
Hi Brash - with our QoS you can either give more bandwidth to specific devices, so in this case your ShorTel device, or if you want a lesser known application, you can also prioritise ports using Traffic Prioritization.
So to answer quickly, yes you can prioritise it!
