reverseproxy
Aug 01, 2019Aspirant
should be simple, but can't port forward.
So, i know there's an abundance of these on the forms, but they don't seem to actually conclude with a proper answer. Long story short, i'm trying to port forward. I've submitted a screenshot of m...
Aug 02, 2019Guru - Experienced User
Has uPnP been disabled after setting up PF rules?
Netduma-Fraser
Aug 06, 2019NetDuma Partner
You may find more frequent and helpful answers if you post this in the correct forum for your router: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
