droesw
Aug 29, 2019Guide
Should I factory reset router before moving?
In a few days I’m going to be moving to a different house and am taking my xr500 with me. It’s going to be with the same isp from my old house but obviously the location and IP address is going to cha...
Aug 29, 2019Guru - Experienced User
Leave the way it is. Just power it off. When you get to the new home and ISP service, power the modem off for 30 seconds then back on, then after connecting the XR, power it on.
Be ware that some modems already have built in routers.
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Netduma-Fraser
Aug 29, 2019NetDuma Partner
As above it isn't necessary. If you fail to get a connection at the new place then go through the setup wizard again in Settings - no need to factory reset to do this.
