droesw
Aug 29, 2019Guide
Should I factory reset router before moving?
In a few days I’m going to be moving to a different house and am taking my xr500 with me. It’s going to be with the same isp from my old house but obviously the location and IP address is going to cha...
Netduma-Fraser
Aug 29, 2019NetDuma Partner
As above it isn't necessary. If you fail to get a connection at the new place then go through the setup wizard again in Settings - no need to factory reset to do this.
droesw
Aug 30, 2019Guide
Would factory resetting it have any potential harm to the router, or do you just think it's unnecessesary? I'm just asking becasue there are some things in the routers settings I need reset, such as list of devices because most of the ones on the router currently won't be used at my new house. It just seems easier to hard reset rather than go through and remove each individual one, unless you think there would be any drawbacks or harm to factory resetting?
