Turtle6969
Apr 03, 2018Tutor
Should I get CM1000 and XR500
I currently have the C7000 Modem/Router combo and have frequent internet speed drops. My ping is usually around 88ms. I have my xbox one hardwired to it but everything else is connected wirelessly....
Turtle6969
Apr 03, 2018Tutor
I was referring to the xbox setting ping, I didn't know that, thank you. Will the geo-filtering prevent me from playing mulitiplayer games like The Division and Destiny with friends from another state?
Netduma-Fraser
Apr 03, 2018NetDuma Partner
We have a feature called Deny & Allow to ensure that you can allow your friends so they're unaffected by the Geo-Filter settings & you can connect to them no matter what.
We tested The Division awhile back and you're unable to use the Filtering aspect of the Geo-Filter with it. Their online may have changed since then so that you can but regardless you can still see the host on the map and ping it.
