JonnyC777
Apr 18, 2025Aspirant
Sky Max getting installed, would like to use my XR500 router instead of supplied Sky Router
Hello We are switching from Virgin to Sky for our broadband provider. Currently we use our Virgin Hub 5 in modem mode with our XR500 as our router. Sky hub has no modem mode and we would...
JonnyC777
Super thanks for the quick response!
Now need to research what you said!!! No doubt will be back..
Happy Easter
Netduma-Fraser
Apr 18, 2025NetDuma Partner
You may need to use DHCP Option 61 also but I can't say for certain if Sky still require that
- JonnyC777Apr 25, 2025Aspirant
Hello, back again...
We are considering the following as our set up.
Virgin Hub 5 in modem mode with XR500 (this is our existing setup)
The above would be for the kids devices, tv's, printers, phones etc etc.
Sky Max Hub used ONLY with wired connections to two PC's with wifi turned off on the Sky Max Hub
Is there anything with the above setup that could cause issues between themselves.
Thanks again for looking.
- FURRYe38Apr 25, 2025Guru - Experienced User
If the 2 PCs connected to the Sky Hub don't need any resources from the XR router side, then you could use this configuration.
Thanks for the reply, we will go with this setup.
- Netduma-FraserApr 25, 2025NetDuma PartnerAs above that should be absolutely fine
