KyleP6912
Apr 20, 2020Aspirant
Slow download speed xr500
When I started I had the XR500 directly connected to my ont was getting around 95 down and up which is about 1/3 of what I pay for. So I hooked my gateway back to the ont and the gateway to the XR500 ...
Netduma-Fraser
Apr 21, 2020NetDuma Partner
If you disable QoS completely from the Anti-Bufferbloat option menu do you see your speeds return? Also how are you testing via wifi or ethernet?
