KyleP6912
Apr 20, 2020Aspirant
Slow download speed xr500
When I started I had the XR500 directly connected to my ont was getting around 95 down and up which is about 1/3 of what I pay for. So I hooked my gateway back to the ont and the gateway to the XR500 ...
D-mny93
Apr 28, 2020Star
I’m still fighting to get one...
Netduma-Fraser
Apr 28, 2020NetDuma Partner
Did you try my previous suggestion to see if that works?
- D-mny93Apr 28, 2020StarYes, I’ve also tried factory reset, change MTU size, and everything else they had me do.
- Netduma-FraserApr 29, 2020NetDuma PartnerDo the startup wizard again, does that speedtest report your correct speeds?
