KyleP6912
Apr 20, 2020Aspirant
Slow download speed xr500
When I started I had the XR500 directly connected to my ont was getting around 95 down and up which is about 1/3 of what I pay for. So I hooked my gateway back to the ont and the gateway to the XR500 ...
Netduma-Fraser
Jul 18, 2020NetDuma Partner
Hi Amar, have you set the speeds you expect in the Anti-Bufferbloat options? What is your exact physical setup?
AmarD
Jul 18, 2020Aspirant
Anti-bufferbloat is always and yes everything is on.
I'm not sure as I just got my xr500
- Netduma-FraserJul 19, 2020NetDuma PartnerAre you using a modem/router? Is it connected directly to the XR? Are ALL devices connected to the XR or are some connected to the modem/router?
- AmarDJul 20, 2020Aspirant
modem that is connected to my router
all devices are connected to my xr
im just not sure what is causing this to happen
- Netduma-FraserJul 20, 2020NetDuma PartnerIn the Device Manager click the 3 line icon in the top left of the panel, switch to the table view. What do the link speeds say for the WAN/Internet and LAN ports?
