Compoza_
Mar 08, 2021Luminary
Slow download speed
Hi! I have internet speed 500 mg download and 100 mb upload and I get lower download speed on router xr300 compared to my ISP's router. I get 450-500 mb download speed with my ISP's router, and I get...
- Mar 08, 2021
Do you have QoS enabled? Do your speeds return to full when you fully disable QoS from the menu in Congestion Control?
Compoza_
Hi again! I found the menu and have disabled the QoS and it works! Just now I got 490 mb download speed :) But what happens when it is disabled?
Netduma-Liam
Mar 09, 2021NetDuma Partner
Good to hear! Everything is working properly then. QoS throttles your bandwidth speed to ensure it can control traffic on your network, if you run a connection benchmark with QoS enabled you should still see the speedtest shows your full speeds.
- XcelMar 10, 2021Apprentice
This is not normal operation. With QOS enabled and with congestion control at 100%, you should be getting full speeds. There is something wrong with QOS as I am having the same issue
- Netduma-FraserMar 10, 2021NetDuma PartnerQoS is still active in that scenario so depending on what is set it can differ
