Xboxonex7
Jan 11, 2019Aspirant
Slow download speeds
Hey guys I’ve tried everything but I’m getting slow download speeds to my Xbox one x. Let me start by saying my set up. First off arres modem straight cat to xr500. Xr500 to Xbox one x. Now in the xr5...
Netduma-Fraser
Jan 12, 2019NetDuma Partner
First of all I'd disable IPv6. Secondly, so you're saying it works absolutely fine when you have your DNS changed? If so that's great just leave you DNS as that, it'll be better than the ISP standard DNS anyway!
Xboxonex7
Jan 12, 2019Aspirant
I can disable ipv6 but I thought there was a advantage to that. Also my ping goes up when I change the dns. I was hoping for a solution to the problem because keeping my dns and this happening isn’t right. Remember this is a 300+ dollar router.
- Netduma-FraserJan 12, 2019NetDuma PartnerIt won't really give you an advantage. How much does it go up by? Try 1.1.1.1 and 1.0.0.1 instead. Routers are rarely ready to go immediately they'll always require a bit of configuration, you've found this as a solution so try the above one and see if it still works and your ping stays the same
- Xboxonex7Jan 12, 2019AspirantDisabled 6 still not good plus new dns you have me gives me packet loss no bueno. Anything else?
- Netduma-FraserJan 12, 2019NetDuma PartnerI can't imagine DNS increasing your ping that much. Try 8.8.8.8 / 8.8.4.4
