wait_i-m_low
Mar 29, 2019Guide
Slow DumaOs
Hey! I think my DumaOs is pretty slow, don’t know why. Although the Geofilter isn’t working in the right way. I get players from outside my Geofilter even the filter mode is activated. When I’m ...
Mar 29, 2019Guru - Experienced User
What version of FW are you using?
What browser are you using? Happen in FF or Opera?
wait_i-m_low
Mar 29, 2019Guide
The last firmware that is available.
I test it on pc with ff and ie and on my Mac with safari
- FURRYe38Mar 29, 2019Guru - Experienced User
Try a factory reset on the XR and setup from scratch.
Clear ALL browser caches, then open the routers web page.
- wait_i-m_lowMar 29, 2019GuideOkay i will try that.
I already did a factory reset but didn’t delete the browser- FURRYe38Mar 30, 2019Guru - Experienced User
Let us know if it helps...I Think NG is aware of the slow down.
