Noahh
Feb 08, 2020Guide
Slow ethernet speed Xr 450
I have at&t fiber 300 mb speed and I use a power line adapter and when I test my wired connection I have really good ping but I’m not even close to 100 mb and when I’m using wireless I’m getting m...
Netduma_Alex
Feb 11, 2020NetDuma Partner
If you go to Device Manager, could you change your device's type from Computer to Xbox or PlayStation.
Now delete the device from Geo-Filter and add it again. Now it should work with Fortnite.
Noahh
Feb 11, 2020Guide
Ok I will try this and reply back what happens
