Mareon
Aug 14, 2019Initiate
Slow Internet Speed
So recently I started a contract with Hues Net because it’s the only internet provider around here and the speeds are horrible and, my son is a heavy gamer and I don’t want his games to lag. So I was ...
Netduma_Alex
Aug 14, 2019NetDuma Partner
Well the NETGEAR Nighthawk Pro Gaming routers have DumaOS installed which allows you, among other things, to balance the devices on your local network so that even under heavy use, your son's gaming will not be interrupted.
This works by stopping any other device (say, your TV) from using so much bandwidth that packets are dropped. By leaving room on the network, your son's games will always have an instant response, and lag will be wiped out.
Mareon
Thank you sir I’ll be sure to check that out
