AzureTorisuna's avatar
Sep 02, 2020
Slow Internet speeds Wired
Alright so I have spent a couple of minutes browsing through the forums here and I cant seem to see one that solves my issue. I have determined that the bottle neck is indeed the nighthawk. I get my ...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Sep 02, 2020
    There is one port limited to 100Mbps which would prevent you from getting higher speeds. Can you try another cable please at least Cat5e in a different port and see if the speeds increase?
