AzureTorisuna
Sep 02, 2020Tutor
Slow Internet speeds Wired
Alright so I have spent a couple of minutes browsing through the forums here and I cant seem to see one that solves my issue. I have determined that the bottle neck is indeed the nighthawk. I get my ...
- Sep 02, 2020There is one port limited to 100Mbps which would prevent you from getting higher speeds. Can you try another cable please at least Cat5e in a different port and see if the speeds increase?
Netduma-Fraser
Sep 02, 2020NetDuma Partner
Did you turn it off completely in the Anti-Bufferbloat 3 line option menu?
AzureTorisuna
Sep 02, 2020Tutor
Like change it to Never? Yes if so and also I triple tried the above guide and what not. Cant get the situation to improve.
Edit: Sorry I now see that you can further disable it and Yes I did do this and nothing has improved.
- plemansSep 02, 2020Guru - Experienced User
What gateway is it connected to?
- Netduma-FraserSep 02, 2020NetDuma PartnerCould you provide a screenshot of the Device Manager table view please?
- AzureTorisunaSep 02, 2020Tutor
the attached picture is the table view.
