AzureTorisuna
Sep 02, 2020Tutor
Slow Internet speeds Wired
Alright so I have spent a couple of minutes browsing through the forums here and I cant seem to see one that solves my issue. I have determined that the bottle neck is indeed the nighthawk. I get my ...
- Sep 02, 2020There is one port limited to 100Mbps which would prevent you from getting higher speeds. Can you try another cable please at least Cat5e in a different port and see if the speeds increase?
AzureTorisuna
Sep 02, 2020Tutor
the attached picture is the table view.
Netduma-Fraser
Sep 02, 2020NetDuma Partner
- AzureTorisunaSep 02, 2020Tutor
This seemed to have worked. The cable though is cat6 so I will need to find a not so faulty cable or limit the TV to wireless. Thanks for the help there. If I explored a bit more and saw the table view sooner that would have helped. Again thank you.
