mpparent
Aug 07, 2019Aspirant
Slow LAN on R9000
Folks,
Are you seeing volatile download speeds on your r9000? I will get 50 Mbps at times...then I'll restart my computer and get over 500 Mbps. My upload speeds seem to be ok, at around 600-700 Mbps. Any ideas? The other odd thing is that my TV subscription is via an internet connection delivered through my router. The video freezes (which I've determined to be a slow LAN connection) from time to time. Weird...
1 Reply
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
You might try Voxels 3rd party FW as well.
Good Luck.
mpparent wrote:Folks,
