WindfallNL
Aug 13, 2019Aspirant
Slow local traffic with XR500
Setup : internet modem -> router (XR500) -> computer 'M' -> VM on 'M'. VM runs web server. Web server has a 5 MB gzipped page for index.html. A domain name 'D' is mapped to the WAN address of the m...
Aug 13, 2019Guru - Experienced User
- Netduma-FraserAug 13, 2019NetDuma PartnerHow are you accessing the local site specifically? Are you using HTTPS? If so is it faster using HTTP?
- WindfallNLAug 13, 2019Aspirant
Netduma-Fraser wrote:
How are you accessing the local site specifically? Are you using HTTPS? If so is it faster using HTTP?I simply browse the domain name with Firefox. It's all HTTPS. If HTTP is used, it is automatically redirected to HTTPS.
- Netduma-FraserAug 13, 2019NetDuma PartnerThat could be why, is there a way you could disable HTTPS briefly for the server and check with HTTP to see if its faster?
FURRYe38 wrote:What Firmware is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?Firmware V2.3.2.40
The modem is a Ziggo 'Connect box', no doubt it is rebadged but I can't find relevant info. They used to be Zyxel brand modems.
