WindfallNL
Aug 13, 2019Aspirant
Slow local traffic with XR500
Setup : internet modem -> router (XR500) -> computer 'M' -> VM on 'M'. VM runs web server. Web server has a 5 MB gzipped page for index.html. A domain name 'D' is mapped to the WAN address of the m...
Netduma-Fraser
Aug 13, 2019NetDuma Partner
How are you accessing the local site specifically? Are you using HTTPS? If so is it faster using HTTP?
WindfallNL
I simply browse the domain name with Firefox. It's all HTTPS. If HTTP is used, it is automatically redirected to HTTPS.
- Netduma-FraserAug 13, 2019NetDuma PartnerThat could be why, is there a way you could disable HTTPS briefly for the server and check with HTTP to see if its faster?
- WindfallNLAug 13, 2019Aspirant
I removed the 301 response for HTTP requests (I actually wrote this server myself), restarted the server and explicitly browsed HTTP. No difference.
I'm not surprised, because, as I reported in my original message, browsing from somewhere offsite is fast, whereas browsing onsite to the same thing is not.
This cannot be anything but a routing issue (or something along the route doing deep packet inspection really inefficiently), and the XR500 remains my main suspect.
- Netduma-FraserAug 13, 2019NetDuma PartnerThanks for trying, with QoS completely disabled it won't be interacting with any packets. This might be one to contact Netgear directly about as they may have seen this on their non DumaOS routers http://support.netgear.com/
