redfall
Jul 10, 2020Aspirant
SLOW, REBOOTS RANDOMLY Nighthawk x6 AC3200 R8000 router
Router is randomly rebooting. Dropping connections both wifi and ethernet. It is not supporting the 400 Mbps. Wants to limit it to ~100 Mbps (default settings). If directly connected to cable modem i...
- Jul 10, 2020
What firmware are you on?
What modem are you using?
Qos isn't recommend at speeds >250mbps.
A simple thing to try (if you don't have a lot of specialized settings) is a factory reset and reinstall. The R8000 got the netgear armor update and responded well to a simple factory reset and reinstall.
Jul 10, 2020Guru - Experienced User
- redfallJul 10, 2020Aspirant
1. Firmware version V1.0.4.56_10.1.71
2. Spectrum issued Hitron DOCSIS 3.1 cable modem
3. Will disable QoS, thanks!
Will reset again. I don't use netgear armour. should I?
- plemansJul 10, 2020Guru - Experienced UserI wouldn't use armor unless you're wanting/needing the services it offers.
