gamer_316
Sep 15, 2020Aspirant
Slow speeds on XR300
Been looking across the internet to try & find solutions to my speeds being slowed down to half or less from what I was getting before. I moved into this apartment where the equipment wasn’t mine & I ...
Sep 16, 2020Guru - Experienced User
If you connect a pc/laptop directly to the modem's port 1, what speeds do you get? (reboot the modem after disconnecting router, then hook up pc)
What firmware is on the xr300?
Optimal settings guide is found here
http://support.netduma.com/support/solutions/folders/16000090646
Netduma-Fraser
Sep 16, 2020NetDuma Partner
Would suggest using the guide above. How exactly have you given priority to the PS4?
