gamer_316
Sep 15, 2020Aspirant
Slow speeds on XR300
Been looking across the internet to try & find solutions to my speeds being slowed down to half or less from what I was getting before. I moved into this apartment where the equipment wasn’t mine & I ...
Sep 16, 2020Guru - Experienced User
If you connect a pc/laptop directly to the modem's port 1, what speeds do you get? (reboot the modem after disconnecting router, then hook up pc)
What firmware is on the xr300?
Optimal settings guide is found here
http://support.netduma.com/support/solutions/folders/16000090646
gamer_316
Sep 17, 2020Aspirant
After doing speed tests on my PS4 via being connected to the modem I ran 5 tests and I got 119.7Mbps, 348.8Mbps, 353 Mbps, 151.4Mbps, and 357.5Mbps. I had my PS4 prioritized from the QoS giving my game consoles the most bandwidth usage. I haven't changed anything yet for the optimal settings yet to allow the speeds come through properly and the firmware is on whatever the newest firmware to date, I don't have a PC or laptop so I don't think I'd be able to install an older firmware if all else fails.
- plemansSep 17, 2020Guru - Experienced User
And what speeds do you pay for?
- gamer_316Sep 17, 2020Aspirant
Honestly I'm not sure, my landlord pays for the internet but seeing as how I can get around 350 I'd like to aim for that but I'm generally happy if I can maintain speeds 100-150
im messing with the settings to get high speeds and I'm not seeing a "disable IPv6" option. I went to settings then advanced settings then IPv6 but I don't see any option to disable it.
Also does the CM1200 have a bridge mode? I did a quick Google search & saw someone say that a modem that isn't a modem+router combo doesn't have that, it's always in modem mode, is that correct?
- Netduma-FraserSep 17, 2020NetDuma Partner
That's a pure modem so nothing to do in that regard. It seems like from the tests you did that the speed fluctuates heavily which isn't ideal from a diagnosis perspective. Follow the guide and make the changes to try to get max speeds and see what the PS4 gets.
