gamer_316
Sep 15, 2020Aspirant
Slow speeds on XR300
Been looking across the internet to try & find solutions to my speeds being slowed down to half or less from what I was getting before. I moved into this apartment where the equipment wasn’t mine & I ...
gamer_316
Sep 17, 2020Aspirant
After doing speed tests on my PS4 via being connected to the modem I ran 5 tests and I got 119.7Mbps, 348.8Mbps, 353 Mbps, 151.4Mbps, and 357.5Mbps. I had my PS4 prioritized from the QoS giving my game consoles the most bandwidth usage. I haven't changed anything yet for the optimal settings yet to allow the speeds come through properly and the firmware is on whatever the newest firmware to date, I don't have a PC or laptop so I don't think I'd be able to install an older firmware if all else fails.
Sep 17, 2020Guru - Experienced User
And what speeds do you pay for?
- gamer_316Sep 17, 2020Aspirant
Honestly I'm not sure, my landlord pays for the internet but seeing as how I can get around 350 I'd like to aim for that but I'm generally happy if I can maintain speeds 100-150
im messing with the settings to get high speeds and I'm not seeing a "disable IPv6" option. I went to settings then advanced settings then IPv6 but I don't see any option to disable it.
Also does the CM1200 have a bridge mode? I did a quick Google search & saw someone say that a modem that isn't a modem+router combo doesn't have that, it's always in modem mode, is that correct?
- Netduma-FraserSep 17, 2020NetDuma Partner
That's a pure modem so nothing to do in that regard. It seems like from the tests you did that the speed fluctuates heavily which isn't ideal from a diagnosis perspective. Follow the guide and make the changes to try to get max speeds and see what the PS4 gets.
I am but I'm at the part where it says to disable IPv6 and I don't see that option
