Pblou916
May 25, 2020Aspirant
Slow Speeds via Wifi and hardline with the XR500
I just in stalled the new Modem and Router. Once i did so my speeds droped from 900+mbs to under a 100mbs. If i bypass t he router i get the 900+mbs. I have tried disableing QOS and other tricks that...
May 26, 2020Guru - Experienced User
Have you tried replacing the cable?
or manually setting the upload/download speed settings for the router? maybe its using a lower setting
https://kb.netgear.com/000053112/How-do-I-set-up-QoS-on-my-Nighthawk-Pro-Gaming-Router
- Pblou916May 26, 2020AspirantI have a few different variations from I have read to see if maybe that was issue but no luck.
These are the combos I tried.
1. 95/50
2. 95/95
3. 97/97
4. 85/50- plemansMay 26, 2020Guru - Experienced User
did you try changing cables?
And why are you manually setting a low speed than what you're getting?
manually set your isp speeds for the gigabit you subscribe to and the modem puts out. (according to your prior statements)
- Netduma-FraserMay 26, 2020NetDuma PartnerIn Anti-Bufferbloat options set 1000/50, then also disable QoS from that option. Confirm that in Device Manager table view that your ports are connecting at link speeds of 1000mbps. Do a wired speed test, if it's still an issue set the MAC address of the router to the MAC address of your old router in the Internet Setup page and then reboot and try again. It can sometimes take a few days to sync properly with the ISP and this can result in lower speeds temporarily.
