joblack85
Oct 29, 2020Aspirant
slow speeds xr300
hello guys, not really a tech guy so I'm lost on what I should do to get my speed to where they need to be. I'm on comacst 1000mbps gigabit and I have a xr300. my ps4 is only giving me 200mbps lan a...
Netduma-Fraser
Oct 30, 2020NetDuma Partner
What do you get from a wired PC? Have you set your bandwidth speeds on the router interface?
joblack85
Oct 30, 2020Aspirant
wired I'm not getting more than 200mbps and I don't know how to set speeds on the router interface
- Netduma-FraserOct 30, 2020NetDuma PartnerIn QoS, in the top left of the Anti-Bufferbloat panel is a 3 line icon, click that and you can enter it there. Would recommend taking a look at these guides which includes one for getting max speeds:
http://support.netduma.com/en/support/solutions/folders/16000090646 - plemansOct 30, 2020Guru - Experienced User
joblack85 wrote:wired I'm not getting more than 200mbps and I don't know how to set speeds on the router interface
You're getting 200mbps directly connected to the modem? Or is that from the XR300?
And the XB7 is a modem router combo device with its own integrated qos/bandwidth management.
do you have the xb7 in bridge mode? This disabled is own routing functions.
https://www.xfinity.com/support/articles/wireless-gateway-enable-disable-bridge-mode
