ROD211973
Feb 15, 2020Aspirant
SLOW SPEEDS
I have the netgear xr700 router netgear cm1150v modem and im not getting my full speeds coming out the router but im getting full speed out the modem
Feb 16, 2020Guru - Experienced User
What speeds do you pay for?
What speeds do you get from the modem?
What speeds do you get directly off the modem?
What speed do you have set for your Qos settings? You can manually adjust this.
ROD211973
Feb 16, 2020Aspirant
i pay for 1 gig down and 42 up but when coming straight out the modem i get between 920-940 down load and always get 42-43 up load but when going through the router its 400-600 down and 42-43 upload.I have the qos at 940 down 42 up
- plemansFeb 16, 2020Guru - Experienced User
Have you tried disabling qos, rebooting, and checking speed?
- ROD211973Feb 16, 2020Aspirant
yes still slow speeds
- Netduma_AlexFeb 17, 2020NetDuma Partner
Are you using a gigabit compatible ethernet cable? Have you tried multiple cables in case your original one is broken?
