Alex0244
Oct 29, 2018Tutor
Slow upload speeds with xr500
I ussed to get 32-35mbps upload with my previous Linksys router. Since buying my XR500, I have been getting 2-3mbps upload. This is occurring both wired and wireless. And I’ve noticed it more on the X...
Alex0244
Oct 29, 2018Tutor
It is set to default settings for that, I haven’t touched it. Wired and wireless is same upload speed (at least on Xbox)
Netduma-Fraser
Oct 29, 2018NetDuma Partner
Set the MAC address of the XR500 to the MAC address of your previous router.
What speeds do you get on a wired speed test though as console speed tests can be inaccurate.
- Alex0244Oct 29, 2018TutorWill do, I’ll keep you posted
- Alex0244Nov 06, 2018TutorStill having issues even after switching MAC addresses to old router
- Alex0244Nov 06, 2018TutorI’m also aware of speed test inaccuracy with consoles, however; my old router was supplying at least 30 mbps upload and that’s what I’m getting on all my devices except the Xbox
- FURRYe38Nov 06, 2018Guru - Experienced User
What are you speeds with a wired PC connected to the router and using a browser like FF or Opera?
Is the Xbox wired or wireless connected to the router?
Turn OFF QoS and set sliders to 99%
What does the speed report on the router? Tyr manually inputting your spec UP and Down speed on the router.
Alex0244 wrote:
I’m also aware of speed test inaccuracy with consoles, however; my old router was supplying at least 30 mbps upload and that’s what I’m getting on all my devices except the Xbox- Alex0244Nov 06, 2018TutorWired test 31.5 mbps upload
