Alex0244
Oct 29, 2018Tutor
Slow upload speeds with xr500
I ussed to get 32-35mbps upload with my previous Linksys router. Since buying my XR500, I have been getting 2-3mbps upload. This is occurring both wired and wireless. And I’ve noticed it more on the X...
Jan 30, 2019Guru - Experienced User
Have you done a hard power OFF of the xbox? Hold the power button until it shuts off. Then turn it back on?
What are speeds if you wirelessly connect the xbox to the router?
Only thing I would try is a factory reset. Set up from scratch and this time, skip any QoS features. Just do a quick test with the xbox and see if the speed changes any.
Alex0244 wrote:
I ussed to get 32-35mbps upload with my previous Linksys router. Since buying my XR500, I have been getting 2-3mbps upload. This is occurring both wired and wireless. And I’ve noticed it more on the Xbox, any suggestions???
