Alex0244
Oct 29, 2018Tutor
Slow upload speeds with xr500
I ussed to get 32-35mbps upload with my previous Linksys router. Since buying my XR500, I have been getting 2-3mbps upload. This is occurring both wired and wireless. And I’ve noticed it more on the X...
Netduma-Fraser
Feb 20, 2019NetDuma Partner
Okay so could potentially indicate issues on the ISP side then. Surprised they asked for a traceroute/took it as an issue indicator as they can be inaccurate. The timeout could just indicate that a hop couldn't be found and so it would just skip that out, it happens all the time and generally isn't something I would necessarily focus on. Though obviously don't mention that to ATT. When they do send the tech around make sure that you have unplugged the router previously. If they see that you are using something other than their own equipment they will blame it immediately and they won't pay attention to what you're saying so just avoid mentioning the router at all.
chiromike
Feb 21, 2019Guide
Do you mean I should remove the XR500 router from the connection to the CM-1000 Modem? ATT was actually who I used for fiber, I have comcast Xfinity Extreme 250 mbps service that is coming out to check the connection. I'm using all of my own equipment so I'm not sure if they are going to immediately say that they cannot help me because of that. They are goign to charge me $75 for the visit unless they can find somehting that is causign the issue. We'll see how it goes.
- Netduma-FraserFeb 21, 2019NetDuma PartnerYes remove the XR500 router from your network. They might do that so be prepared, I would double check connected to the modem that you still see those issues just so you're not caught out on the day if it all seems fine.
- chiromikeFeb 25, 2019Guide
Just wanted to give an update after my visit from a comcast tech. He performed a couple diagnostic tests in which he then when to the main internet room in my apartment complex and added new connectors ot the wiring to start off things. He spent over an hour helping me and answering questions for me which was nice of him. After he changed the wiring he then checked out the coaxial inputs where my router was going too and show me what could be causing the issue with so many splitters connected. He rewired a few things there as well and added a noise filter to the cable going through the coaxial wire. He then showed me through his tests that everythign was clear and no bad signal was showing up or packet loss.
Unforturnaly even after all that he did I still was experiecing some lag in about 50 % of my games that I was playing on FIFA. I tried changing some of the XR500 settings and still nothing. I'm kinda giving up at this point since I can't find a solution after months of trying to figure it out. I don't usually give up on things but this one I just can't find a solution for :-/
- Alex0244Feb 25, 2019TutorLet me ask you this? When you do a wireless speed test from your phone, do you still get slow upload speeds or is it just on the console?
- Netduma-FraserFeb 26, 2019NetDuma PartnerHave you done any more Ping Plots after the changes he made? I just had a quick look back and you did have a big spike at one point.
Also your base ping is 40ms going off that which is pretty high. So it means even if you lived really close to a server 40ms is the absolute minimum you could get but would generally expect you to get roughly 10-25ms higher than base ping. What sort of pings are you seeing for the game? - chiromikeFeb 26, 2019Guide
I'll have to get back to you on the checking of the upload speed through speedtest.net on my phone as apose ot my console.
I also have not checked the pingplotter to see if there are any spike issues, I'll do that when i get home later as well.
With the geofilter set to 40 ms I am only getting the 37-40 ms range. I have never seen a speed quicker than that range with the exception of when I had Fiber internet where the ping was 8-12 ms. WIth comcast the pest that I have seen on my console has been the 37-40 range that I mentioned. Although even with those ranges I have played games that the speeds have bee perfect, but then the very next game the lag would be noticeable. I'll run a few tests later with the new wiring that was performed to see what I get and will get back to you.
- chiromikeFeb 27, 2019Guide
So after doing the speedtest and ping plotter these were the results. The first picture is from my cellphone, 2nd picture from the laptop (thru ethernet), and the ping plotter results thru my laptop. The connection seems to have no ping spikes on pingplotter after doing it and the upload speeds all around seem to be great on the cellphone at 21.8 mbps (12 ms ping) and laptop at 23.79 mbps (11ms ping).
- Netduma-FraserFeb 27, 2019NetDuma PartnerI can't see the picture but that's really great news, glad to hear it seems to be working better!
