Naxterra
Aug 09, 2018Apprentice
Slow video streaming and mobile connectivity issues
Hello
I am getting very slow speeds when watching videos. It can be either known networks like Youtube, Netflix, etc or other streaming sites like Rapidvideo, Streamango, Mp4upload, etc.
I ha...
Netduma-Fraser
Aug 09, 2018NetDuma Partner
Disable QoS completely from Anti-Bufferbloats options to double check that's not throttling you. If your still have the issue after that then there may be an issue elsewhere. Do you get your full speeds when doing a speedtest?
For WiFi disable smart connect and connect to the individual bands and use a WiFi analyser to find the least congested channels and change to those.
Naxterra
Hello
QoS Anti Bufferbloat already set to "Never". I changed channels according recommendations of first wifi analyser program that I found in Google Play store (2.4Ghz to 7, 5Ghz to 44) but still same.
Smart connect is not enabled
Enable SSID Broadcast enabled
Enable 20/40 MHz Coexistence enabled
Guest network disabled
I am getting full speed on PC around 680-700 mbit, and around 400mbit download / upload speed with my wifi connection on phone. My PC is directly connected to router via CAT7 cable. All others are using Wifi. Also if I select 5Ghz channel 52 and above, my devices are not seeing my wifi.
Best regards
Nax
