Naxterra
Aug 09, 2018Apprentice
Slow video streaming and mobile connectivity issues
Hello
I am getting very slow speeds when watching videos. It can be either known networks like Youtube, Netflix, etc or other streaming sites like Rapidvideo, Streamango, Mp4upload, etc.
I ha...
Naxterra
Hello
QoS Anti Bufferbloat already set to "Never". I changed channels according recommendations of first wifi analyser program that I found in Google Play store (2.4Ghz to 7, 5Ghz to 44) but still same.
Smart connect is not enabled
Enable SSID Broadcast enabled
Enable 20/40 MHz Coexistence enabled
Guest network disabled
I am getting full speed on PC around 680-700 mbit, and around 400mbit download / upload speed with my wifi connection on phone. My PC is directly connected to router via CAT7 cable. All others are using Wifi. Also if I select 5Ghz channel 52 and above, my devices are not seeing my wifi.
Best regards
Nax
Netduma-Fraser
Aug 09, 2018NetDuma Partner
Traffic Prioritization could be taking effect which is why I mentioned to completely disable QoS. If you're getting those speeds then there should be no reason you're having this issue so would recommend calling Netgears 24/7 support line if my suggestion doesn't work. It's because they're DFS channels.
- NaxterraAug 09, 2018Apprentice
Hello
Do they have an email address? I don't want to call USA from Poland, due to calling costs. Also my support status is like below.
Product Hardware Phone Support Chat Support Email Support XR500 (XXXX)
