stijnmeijer
Jun 02, 2018Aspirant
Slow WIFi speed
Dear Community,
I have the NetGear XR500 gaming version but there is some problem with my internet range and upload speed.
speedtest result: http://www.speedtest.net/result/7361170157
R...
Netduma-Fraser
Jun 02, 2018NetDuma Partner
What are the speeds you are expecting? It is likely you have QoS enabled which limits your speed to ensure no local congestion. For range I’d suggest disabling smart connect, then you can connect to 5Ghz which has increased range.
stijnmeijer
Jun 04, 2018Aspirant
Everything works fine even the upload speed when i’m connecting wireless to the 5G network but when the LAN cable is plugged in the upload speed slows down.
