stijnmeijer
Jun 02, 2018Aspirant
Slow WIFi speed
Dear Community,
I have the NetGear XR500 gaming version but there is some problem with my internet range and upload speed.
speedtest result: http://www.speedtest.net/result/7361170157
R...
stijnmeijer
Jun 04, 2018Aspirant
Everything works fine even the upload speed when i’m connecting wireless to the 5G network but when the LAN cable is plugged in the upload speed slows down.
Netduma-Fraser
Jun 04, 2018NetDuma Partner
That sounds almost exclusively like the LAN cable is the issue, do you have another one that you can use to see if that resolves the issue?
