PTjlem's avatar
PTjlem
Follower
Jan 02, 2021
Slow wireless speeds
I am getting very slow speed tests on wireless (40 Mbps) sitting the same room as the router even though when wired I am getting up to 480 Mbps. Not sure where to go from here. Thanks for any thoughts.
1 Reply
  • Are you using Smart Connect? If you disable this and connect to 5GHz what do you get? What device are you using to test and where are you doing the speedtest?
