Opularity's avatar
Sep 29, 2020
Smart roaming with Different Brands
Hey Everyone,
I was wondering if different access points like Ubiquity or just the Unifi Pro ACCESS POINT or any other brand that has smart roaming would work with smart roaming with the ex7700 and xr500. I know between the xr500 and ex7700 smart roaming would work but if I add another brands Access Point and connect it to the network, wpuld it automatically start smart roaming and would the ex7700 pickup the connection from the other access point to extend the network?
Thanks,
  • Yes that should be absolutely fine. They all have to adhere to the basic networking principles so I don't think there is anything specific that would prevent them working together.
    • Opularity's avatar
      Opularity
      Guide
      Thank you, I will try a different AP and keep you updated if features like smart roaming and QOS work.
