astraub
Apr 29, 2020Aspirant
SMB transfer unreliable - frequent drop of the connection to my NAS during Time Machine backup
Hi, after two weeks of testing I am now sure that either my iMac Pro or the XR500 are causing unreliable SMB transfers. I use the 5GHz band through one wall, but only about 1m away from the r...
Netduma-Fraser
Apr 29, 2020NetDuma Partner
When the issue occurs do you notice any disconnect issues on other devices? Are there any WiFi networks in your area? Could be wireless contention causing the issue briefly, use a WiFI analyzer to find the least congested channel and see if that helps. Does it occur on 2.4GHz at all?
astraub
Hi,
no, I did not notice disconnect on other devices. Interference is not very likely (see attached spectrum measurement). Very rarely a second user is also on channel 36, but at a very low level.
I noticed that it usually needs a transfer of a few 100GBytes for the disconnect to occur. What is especially strange, is that the connection recovers very fast after that. I only could find it through log messages - in this case I tried copying to a disk image using Superduper, which clearly indicated that disconnect on the target side in its log after failure. Time machine only indicated a transfer error not telling on which side it happened.
I am not using 2.4GHz at all on the XR500 as it is simply too slow and as you can see far too congested in my area (Picture of spectrum in my area).
Greetings
Andreas
- Netduma-FraserApr 29, 2020NetDuma PartnerCould you try disabling QoS completely from the Anti-Bufferbloat option menu please, I'm wondering if that is interfering with the packets.
