PSling
Aug 09, 2019Follower
Some devices can't see the wireless network
Hi All, I just purchased and connected a XR500 to the NBN (australia) and for some reason almost every device can connect perfectly to the router but I have 2 HP PC's and one Ring Doorbell that when ...
Netduma-Fraser
Aug 10, 2019NetDuma Partner
Could you disable Smart Connect in the WiFi settings please and connect to the 2.4/5GHz WiFi manually and see if they're all able to connect then please?
- chall1029Dec 24, 2019AspirantI have the same problem. Just a few devices can’t see the network. Always the same devices.
- Netduma-FraserDec 24, 2019NetDuma PartnerHave they ever been connected at all? You may need to forget the connection on the devices itself and then try to reconnect with the password.
