PSling
Aug 09, 2019Follower
Some devices can't see the wireless network
Hi All, I just purchased and connected a XR500 to the NBN (australia) and for some reason almost every device can connect perfectly to the router but I have 2 HP PC's and one Ring Doorbell that when ...
chall1029
Dec 24, 2019Aspirant
I have the same problem. Just a few devices can’t see the network. Always the same devices.
Netduma-Fraser
Dec 24, 2019NetDuma Partner
Have they ever been connected at all? You may need to forget the connection on the devices itself and then try to reconnect with the password.
