hawknighty
Mar 27, 2023Follower
Some question about XR1000
Hi All: Here's my first question: Does anybody know if the XR1000 supports bridge mode? This feature can be found in other Netgear Nighthawk models such as the R7000. Another question I have ...
- Mar 27, 2023
Page 146 on the User manual refers to "Enable or disable MU-MIMO". This is not Bridge mode.
I have the XR1000 and XR450/500. They've never supported bridge mode.
Mar 27, 2023Guru - Experienced User
The XR1000 does not support Bridge mode.
https://support.netduma.com/support/solutions/folders/16000090646
hawknighty wrote:
Hi All:
Another question I have is, how do I set up QoS? Regardless of what changes I make to the settings, I don't feel any improvement in my gaming experience. have any suggestions for the setup?
thanks
michaelkenward
That's not what the manual says. See page 146 "Enable Bridge Mode". But who knows given Netgear's dreadful record on that front?
- FURRYe38Mar 27, 2023Guru - Experienced User
- michaelkenwardMar 27, 2023Guru - Experienced User
That is not what it says in my copy of the manual. Dated 2020.
3 years old. Might update your copy then.
NG updated the UM 2023.
