hawknighty
Mar 27, 2023Follower
Some question about XR1000
Hi All: Here's my first question: Does anybody know if the XR1000 supports bridge mode? This feature can be found in other Netgear Nighthawk models such as the R7000. Another question I have ...
- Mar 27, 2023
Page 146 on the User manual refers to "Enable or disable MU-MIMO". This is not Bridge mode.
I have the XR1000 and XR450/500. They've never supported bridge mode.
michaelkenward
Mar 27, 2023Guru - Experienced User
FURRYe38 wrote:
The XR1000 does not support Bridge mode.
That's not what the manual says. See page 146 "Enable Bridge Mode". But who knows given Netgear's dreadful record on that front?
- michaelkenwardMar 27, 2023Guru - Experienced User
That is not what it says in my copy of the manual. Dated 2020.
- FURRYe38Mar 27, 2023Guru - Experienced User
3 years old. Might update your copy then.
NG updated the UM 2023.
That does not explain why the original manual provided that information.
It does not help hawknighty to work out if they can install older firmware and restore that feature.
It does not confirm that the current manual is accurate. (It is also for the V2 hardware.) As I said before many of Netgear's manuals are hopelessly inaccurate and out of date.
If I were hawknighty I would check the interface to see what works. I would also follow my earlier advice and ask the DumaOS people for help.
