Compoza_
Mar 09, 2021Luminary
Something is wrong with the Geo filter
https://imgur.com/a/CJeTmdg It seems like the Geo Filter is broken now, take a look at the picture. Any ideas? Regards
- Mar 10, 2021When that error appears, wait 1 minute and then refresh the page - it will have successfully flushed the cloud. What was the ping to that server?
Netduma-Fraser
Mar 09, 2021NetDuma Partner
It's likely the host is outside your zoom level, if you zoom out fully do you see the host? Did you enable filtering mode/change settings while you were already on the game?
